We are currently working on a new way to help you setup your home automation logic even faster with templates that will tell you exactly which applets to enable and will create Conditions, Logicblocks and Action names for you automatically.
Because of this, we are going to be creating many new applets in IFTTT, as we want to provide the direct link to the applet you need to enable.
Applets created by Apilio do not count towards your 3 free applets with IFTTT
Hi all, I wanted to respond here to some of you who have already answered the survey, thanks for that!
If you need Weather Underground + Sunrise or Sunset, you donât need an applet for this combination anymore as time events and time frames are now native in Apilio. You donât need to setup a variable either: these are created as conditions straight away: For example, if you wanted a condition to make sure your logic only runs during night time, this is what you would setup in Apilio to create this time frame that starts at sunset and finishes at sunrise:
If you are using a variable that is set to true at a specific time of the day (this is a time event, it only happens once a day), for example, a"late-night" variable that is set to true every day at 22:45, you can also set this up in Apilio and you donât need a variable anymore. Youâll also be able to use this as your trigger, without any other applets:
In light of the recent IFTTT changes, with free accounts limited to 3 applets, this example uses the entire allotment. What can be changed to use fewer (none?) IFTTT applets to accomplish this simple automation?
Having native time conditions have already helped. It seems native location conditions are needed, as well. Native Apilio conditions that act as triggers will eliminate a significant amount of user-created IFTTT applets. Then we need Apilio-created IFTTT applets that are flexible enough to be triggered by ANY specified Apilio logicblock and then perform ANY specified service action.
Somehow, we need to get the service (hardware) providers on-board with this. I use WEMO products throughout, because they are compatible with Alexa + Siri + IFTTT. It takes me 4 IFTTT applets just to turn off everything I want when I leave home. WEMO needs to come out with device grouping capability and group actions, which Apilio-created applets can call, triggered by Apilio native conditions (turn a group of devices ON at sunset, turn them off 4 hours later, etc.)
You guys know this as well as me. I am sure you are just as frustrated as I am with the situation.
Hi @clancyduncan! Thanks for your message, we totally understand, we are working to have many applets ready so you can choose the service and the actions as needed.
I can help with the applet limit question: only applets that you create following the link https://ifttt.com/create count towards the 3-applet limit. But any applets that a brand like Apilio creates as a âtemplateâ can be connected and donât count towards the limit. These you can use as many as you like for free.
For our use cases, we are preparing these new templates that will tell you exactly which applet to activate, providing a direct link to the applet that must be connected. For example, for this use case you mention:
This template needs:
1 native time condition in Apilio, to check if itâs dark outside (between sunset and sunrise)
1 external trigger: check that Iâm close to home
2 Actions: one to turn on the light and one to turn it off.
For example, to setup the actions, you will enable the ready-made applets from Apilio, depending on your device.
If you have a Philips Hue light bulb for example, youâll use:
Thanks for the update. I see the applets you have created using the IFTTT Location triggers. Those should help eliminate loads of user-created applets.
IFTTT Location works great for single person households. For users with multi-person households, Life360 works better. Consider creating applets that use the Life360 location triggers; âYou Enterâ, âYou Exitâ, âFirst Person Entersâ and âLast Person Exitsâ. That will help the rest of us eliminate more user-created applets.
On the response side of things, consider applets of the form, âIf IFTTT receives a (fill-in-blank) event from Apilio then (fill-in-blank).â I donât know; maybe more complicated?
If we have fill-in-blank trigger applets and response applets, then almost all the user-created work can be done in Apilio, and not run up against the 3 applet IFTTT limit.
It is also possible to link two IFTTT accounts to the same Apilio account, so you can use the location service:
Depending on your setup, I would also recommend using an applet that checks if your phone is connected or disconnected from a specific WiFi: your home WiFi. This is in some instances more reliable that the Location service to trigger logic that depends on you and/or someone else being home.
The applets we are creating are fill-in-the-blanks in the sense that youâll have to specify which device you want to use, or the event you are listening to, or the variable you want to update.
When creating an applet, we (and any IFTTT brand/user) must specify the trigger and action. Also, same action cannot be repeated (which is something you do on Apilio all the time!).
Remember that any applets that Apilio creates do not count towards your 3 applet limit. So they donât necessarily have to be packed with actions, we can keep them simple and yet flexible
So, apparently, we can only use an Apilio-created IFTTT applet once? For example, if I use the âenter area, set Apilio variableâ applet for one area/variable, then I am unable to use the applet again for a different area, different variable? Is there a way around this limitation?
This is in fact a problem the we werenât fully aware of at the beginning, but there is that limitation as you describe it.
The only way around it that we have found so far is to duplicate (or more) templates. Which would be kind of silly, but if that is whatâs needed, we could even do that.
Iâm still working through trying to migrate as much as I can over and see whether I can make sense of this all before I sign up far IFTTT Pro for a year (though I might do that just to buy myself the time to sort this all outâŚ)
Templates that would be super useful for me would be doing math on numeric variables, and setting numeric variables. The new time triggers look pretty fantastic so far
It also doesnât help that some of my services just decided to stop integrating with IFTTT. Really trying to put the pieces of my âsmartâ home back together. Thanks for all the work yâall are doing!
