Hi everyone!
To support our new templates and also to support all of you, we have been creating a few (or maybe a lot, depending on who you ask ) of ready-made applets.
A friendly reminder that none of these count towards your 3-applet limit.
Are you missing any applets below? Let us know in the comments!
Please note that when we add a new applet, it can take about a day to appear publicly. Thanks!
Appliances
iRobot
Calendars & scheduling
Date & time conditions are now native to Apilio, so you won’t need any external applets:
- How to setup and use time conditions
- How to add a delay to IFTTT actions
- How to setup time constraints for Conditions: delays and timeouts
- Advanced: Cron time conditions - Intro and how to set them up
Google Calendar
- When a specific event on your Google Calendar is going to start, set a variable to true in Apilio
- When a specific event on your Google Calendar is going to start, run an Apilio Logicblock
DIY electronics
Flic
- When I click a Flic button, run a Logicblock
- When I click a Flic button, set a variable in Apilio to true
- When I click a Flic button, set a variable in Apilio to false
Developer tools
Please note that IFTTT does not allow to publish applets that use the webhooks channel.
Environment control & monitoring
AC Cloud Control
- Set the temperature of a AC Cloud Control device when Apilio triggers an action (1)
- Set the temperature of a AC Cloud Control device when Apilio triggers an action (2)
Ecobee
- Set the temperature of an Ecobee thermostat when Apilio triggers an action (1)
- Set the temperature of an Ecobee thermostat when Apilio triggers an action (2)
Heatmiser
- Activate Standby Mode on the selected Heatmiser Thermostat when Apilio triggers and action
- Cancel Standby Mode on the selected Heatmiser Thermostat when Apilio triggers and action
- Set the Temperature on a Heatmiser Thermostat when Apilio triggers and action
- Activate Home Mode on the selected Heatmiser Thermostat when Apilio triggers and action
Nature Remo
- Turn on the air conditioning of a Nature Remo controlled device when Apilio triggers an action (1)
- Turn on the air conditioning of a Nature Remo controlled device when Apilio triggers an action (2)
Netatmo
- If Netatmo Weather Station detects noise, run a Logicblock in Apilio
- If Netatmo Weather Station temperature is above the threshold, set a variable to true in Apilio (1)
- If Netatmo Weather Station temperature is above the threshold, set a variable to true in Apilio (2)
- If Netatmo Weather Station temperature is above the threshold, set a variable to true in Apilio (3)
- If Netatmo Weather Station temperature is above the threshold, set a variable to true in Apilio (4)
- If Netatmo Weather Station temperature is below the threshold, set a variable to false in Apilio (1)
- If Netatmo Weather Station temperature is below the threshold, set a variable to false in Apilio (2)
- If Netatmo Weather Station temperature is below the threshold, set a variable to false in Apilio (3)
- If Netatmo Weather Station temperature is below the threshold, set a variable to false in Apilio (4)
- If Netatmo Weather Station detects rain, set a variable to true in Apilio
Sensibo
- Set the temperature of a Sensibo controlled device when Apilio triggers an action (1)
- Set the temperature of a Sensibo controlled device when Apilio triggers an action (2)
Honeywell Total Connect Comfort
- Set the temperature of a Honeywell Total Connect thermostat when Apilio triggers an action (1)
- Set the temperature of a Honeywell Total Connect thermostat when Apilio triggers an action (2)
Hive Active Heating™ - UK and Europe
- Set the temperature of a Hive thermostat when Apilio triggers an action (1)
- Set the temperature of a Hive thermostat when Apilio triggers an action (2)
Tado Heating
- Set the temperature of a Tado thermostat when Apilio triggers an action (1)
- Set the temperature of a Tado thermostat when Apilio triggers an action (2)
Wireless Tag
- When a Wireless Tag detects a presence, run an Apilio Logicblock
- When a Wireless Tag detects a presence, set a variable in Apilio to true
- Send Wireless Tag temperature (ºC) readings to Apilio (1)
- Send Wireless Tag temperature (ºC) readings to Apilio (2)
- Send Wireless Tag temperature (ºC) readings to Apilio (3)
- Send Wireless Tag temperature (ºF) readings to Apilio
- Send Wireless Tag Brightness readings to Apilio
- Send Wireless Tag Humidity Percentage readings to Apilio
Lighting
Lifx
- Switch ON a LIFX bulb when Apilio triggers an action
- Switch OFF a LIFX bulb when Apilio triggers an action
LightwaveRF lightight
- Turn on a LightwaveRF light when Apilio triggers an action
- Turn off a LightwaveRF light when Apilio triggers an action
- Turn on a LightwaveRF light when Apilio triggers an action (2)
- Turn off a LightwaveRF light when Apilio triggers an action (2)
- Turn on a LightwaveRF light when Apilio triggers an action (3)
- Turn off a LightwaveRF light when Apilio triggers an action (3)
- Turn on a LightwaveRF light when Apilio triggers an action (4)
- Turn off a LightwaveRF light when Apilio triggers an action (4)
- Turn on a LightwaveRF light when Apilio triggers an action (5)
- Turn off a LightwaveRF light when Apilio triggers an action (5)
- When a LightwaveRF light is switched on, set a variable to true in Apilio
- When a LightwaveRF light is switched off, set a variable to false in Apilio
MagicHue
- Switch ON a MagicHue light when Apilio triggers an action
- Switch OFF a MagicHue light when Apilio triggers an action
- Change color of MagicHue lights when an action is triggered in Apilio (1)
- Change color of MagicHue lights when an action is triggered in Apilio (2)
Philipps Hue
- Switch ON a Philips Hue bulb when Apilio triggers an action
- Switch OFF a Philips Hue bulb when Apilio triggers an action
- Change color of Philips Hue lights when an action is triggered in Apilio
- Set a Philips Hue Scene when an action is triggered in Apilio
- Blink Philips Hue lights when an action is triggered in Apilio
- Dim or brighten Philips Hue lights when an action is triggered in Apilio
- Color loop your Philips Hue lights when an action is triggered in Apilio
- Toggle Philips Hue lights on/off when an action is triggered in Apilio
Kasa
- Switch ON a TP-Link Kasa device when Apilio triggers an action
- Switch OFF a TP-Link Kasa device when Apilio triggers an action
- Activate a TP-Link Kasa scene when Apilio triggers an action
Location
IFTTT’s location service
- When I enter an area, run an Apilio Logicblock
- When I exit an area, run an Apilio Logicblock
- When I enter an area, update a variable in Apilio to true
- When I exit an area, update a variable in Apilio to false
Mobile devices & accessories
Android device
- When my phone connects to a specific WiFi, set a variable to true in Apilio
- When my phone disconnects from a specific WiFi, set a variable to false in Apilio
Do button
- When I tap a IFTTT Button Widget, run a Logicblock
- When I tap a IFTTT Button Widget, run a Logicblock (2)
Wyze
- When motion is detected by a Wyze sensor, run an Apilio Logicblock
- When motion is detected by a Wyze sensor, set a variable to true in Apilio
- When motion is detected by a Wyze camera, set a variable to true in Apilio
- Turn Wyze plug ON when Apilio triggers an action
- Turn Wyze plug OFF when Apilio triggers an action
- Turn Wyze camera ON when Apilio triggers an action
- Turn Wyze camera OFF when Apilio triggers an action
- Turn Wyze light bulb ON when Apilio triggers an action
- Turn Wyze light bulb OFF when Apilio triggers an action
- Enable Wyze motion detection when Apilio triggers an action
- Disable Wyze motion detection when Apilio triggers an action
- Turn Wyze notifications ON when Apilio triggers an action
- Turn Wyze notifications OFF when Apilio triggers an action
- Record short video clip with Wyze when Apilio triggers an action
Notifications
IFTTT app notifications
Power monitoring & management
myStrom
electricityMap
- When electricity is low carbon, update a variable in Apilio to true
- When electricity is high carbon, update a variable in Apilio to false
WeMo Smart Plug
- Turn WeMo Smart Plug ON when Apilio triggers an action
- Turn WeMo Smart Plug OFF when Apilio triggers an action
Routers & computer accessories
Google WiFi
- When a specific device connects to Google Wifi, set a variable to true in Apilio (1)
- When a specific device connects to Google Wifi, set a variable to true in Apilio (2)
- When a specific device connects to Google Wifi, set a variable to true in Apilio (3)
- When a specific device connects to Google Wifi, set a variable to true in Apilio (4)
- When a specific device disconnects from Google Wifi, set a variable to false in Apilio (1)
- When a specific device disconnects from Google Wifi, set a variable to false in Apilio (2)
- When a specific device disconnects from Google Wifi, set a variable to false in Apilio (3)
- When a specific device disconnects from Google Wifi, set a variable to false in Apilio (4)
- When a specific device connects to Google Wifi, run an Apilio Logicblock (1)
- When a specific device connects to Google Wifi, run an Apilio Logicblock (2)
- When a specific device connects to Google Wifi, run an Apilio Logicblock (3)
- When a specific device connects to Google Wifi, run an Apilio Logicblock (4)
- When a specific device disconnects from Google Wifi, run an Apilio Logicblock (1)
- When a specific device disconnects from Google Wifi, run an Apilio Logicblock (2)
- When a specific device disconnects from Google Wifi, run an Apilio Logicblock (3)
- When a specific device disconnects from Google Wifi, run an Apilio Logicblock (4)
TP-Link Router
- When a specific device connects to your TP-Link router, set a variable to true in Apilio
- When a specific device disconnects from your TP-Link router, set a variable to false in Apilio
- When a specific device disconnects from your TP-Link router, run an Apilio Logicblock
- When a specific device connects to your TP-Link router, run an Apilio Logicblock
Security & monitoring systems
Blink
- When motion is detected by Blink, run an Apilio Logicblock
- When motion is detected by Blink, set a variable to true in Apilio
Blink Europe
- When motion is detected by Blink (EU), run an Apilio Logicblock
- When motion is detected by Blink (EU), set a variable to true in Apilio
- Arm Blink (EU) when Apilio triggers an action
- Disarm Blink (EU) when Apilio triggers an action
EZVIZ
- Toggle EZVIZ Sleep Mode when Apilio triggers an action
- Toggle EZVIZ Privacy Mode when Apilio triggers an action
- When an EZVIZ alarm event occurs, set a variable to true in Apilio
- When an EZVIZ alarm event occurs, run an Apilio Logicblock
Ring
- When motion is detected by Ring, run an Apilio Logicblock (1)
- When motion is detected by Ring, run an Apilio Logicblock (2)
- When motion is detected by Ring, set a variable to true in Apilio
- When someone rings my Ring Doorbell, run an Apilio Logicblock
Smart hubs & systems
Apilio
- Run a Logicblock from another Logicblock
- Update a Boolean Variable to True when Apilio triggers an action
- Update a Boolean Variable to False when Apilio triggers an action
- Update a Numeric Variable when Apilio triggers an action (1)
- Update a Numeric Variable when Apilio triggers an action (2)
- Update a Numeric Variable with the ingredient value ApilioValue1 when Apilio triggers an action (1)
- Update a Numeric Variable with the ingredient value ApilioValue1 when Apilio triggers an action (2)
- Receive a push notification with an actionable notification from Apilio
- Receive a customized push notification with an actionable notification from Apilio
BroadLink
- Set the temperature of a Broadlink controlled device when Apilio triggers an action (1)
- Set the temperature of a Broadlink controlled device when Apilio triggers an action (2)
eWeLink
- When motion is detected by an eWeLink camera, run an Apilio Logicblock
- When motion is detected by an eWeLink camera, set a variable to true in Apilio
- When motion is detected by an eWeLink Zigbee sensor, run an Apilio Logicblock
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (1)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (2)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (3)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (4)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (5)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (6)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (7)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (8)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (9)
- Turn eWeLink 1-Channel Plug ON or OFF when Apilio triggers an action (10)
- Turn eWeLink 2-Channel Plug ON or OFF when Apilio triggers an action
- Turn eWeLink 3-Channel Plug ON or OFF when Apilio triggers an action
- Turn eWeLink 4-Channel Plug ON or OFF when Apilio triggers an action
- Turn eWeLink 1-Channel Switch ON or OFF when Apilio triggers an action
- Turn eWeLink 2-Channel Switch ON or OFF when Apilio triggers an action
- Turn eWeLink 2-Channel Switch ON or OFF when Apilio triggers an action (2)
- Turn eWeLink 3-Channel Switch ON or OFF when Apilio triggers an action
- Turn eWeLink 4-Channel Switch ON or OFF when Apilio triggers an action
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to true in Apilio
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to true in Apilio (2)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to true in Apilio (3)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to true in Apilio (4)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to true in Apilio (5)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to false in Apilio
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to false in Apilio (2)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to false in Apilio (3)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to false in Apilio (4)
- When your eWeLink Support 1-Channel Switch is turned on or off, set a variable to false in Apilio (5)
- When an eWeLink device goes above a specified power threshold, set a variable to true in Apilio
- When an eWeLink device goes below a specified power threshold, set a variable to false in Apilio
- When your eWeLink 2-Channel Switch is turned on or off, set a variable to true in Apilio
- When your eWeLink 2-Channel Switch is turned on or off, set a variable to false in Apilio
Harmony
- Start a Harmony activity when Apilio triggers an action (1)
- Start a Harmony activity when Apilio triggers an action (2)
Life360
- When you arrive at a Life360 place, run an Apilio Logicblock
- When you leave a Life360 place, run an Apilio Logicblock
- When you arrive at a Life360 place, set an Apilio variable to true
- When you leave a Life360 place, set an Apilio variable to false
RoomMe
SmartThings
- When SmartThings detects a presence, update a variable in Apilio to true
- When SmartThings no longer detects a presence, update a variable in Apilio to false
- When a SmartThings device is switched on, set a variable to true in Apilio
- When a SmartThings device is switched on, set a variable to true in Apilio (2)
- When a SmartThings device is switched off, set a variable to false in Apilio
- When a SmartThings device is switched off, set a variable to false in Apilio (2)
- When a SmartThings device is opened, set a variable to true in Apilio
- When a SmartThings device is closed, set a variable to false in Apilio
- When a SmartThings device is opened, set a variable to true in Apilio (2)
- When a SmartThings device is closed, set a variable to false in Apilio (2)
- When a SmartThings device is opened, set a variable to true in Apilio (3)
- When a SmartThings device is closed, set a variable to false in Apilio (3)
- When a SmartThings device is opened, set a variable to true in Apilio (4)
- When a SmartThings device is closed, set a variable to false in Apilio (4)
- When a SmartThings device is opened, set a variable to true in Apilio (5)
- When a SmartThings device is closed, set a variable to false in Apilio (5)
- When a SmartThings device is opened, set a variable to true in Apilio (6)
- When a SmartThings device is closed, set a variable to false in Apilio (6)
- When SmartThings detects a presence, run an Apilio Logicblock
- When SmartThings detects a presence, set a variable to true in Apilio
- Switch SmartThings device ON when Apilio triggers an action
- Switch SmartThings device OFF when Apilio triggers an action
- Lock SmartThings device when Apilio triggers an action
- Unlock SmartThings device when Apilio triggers an action
- Activate strobe/siren on SmartThings device when Apilio triggers an action
- Deactivate strobe/siren on SmartThings device when Apilio triggers an action
Wiser Heat
Voice assistants
Amazon Alexa
- Alexa trigger this Apilio Logicblock!
- When you add an item to your Alexa To Do list, run an Apilio Logicblock
- When you add an item to your Alexa Shopping list, run an Apilio Logicblock
- When your Alexa Timer goes off, run an Apilio Logicblock
- When your Alexa Alarm goes off, run an Apilio Logicblock
Google Assistant
- Ok Google! Run this Apilio Logicblock
- Ok Google! Run this Apilio Logicblock (2)
- Ok Google! Run this Apilio Logicblock (3)
Weather
Sunset and Sunrise conditions can be created natively with Apilio, see how:
