Hi… I have a logic block which will update an Apilio’s variable. At the moment I’m doing it via ifttt webhook, but can I do it directly from Apilio to avoid additional delay and possible error?
Hello @arianto.nugroho!
This is not possible at the moment, so you are doing it correctly going over IFTTT.
It’s something that has been requested before, so we might look into building this in the future:
I recommend that if you are still using the legacy webhooks, that you switch over to our IFTTT integration, you can learn more about this change here:
Hi @arianto.nugroho ! Sorry for the delay updating this post but this year we released webhooks in Apilio and they allow you to update a variable via a Logicblock without using IFTTT. I added some steps on how to do this here:
