Unable to create new Logic Block with Tuya action
Hi all,
I’m having an issue today when I try to create a new Logic Block.
I get an error “Your account is creating an unusual high number of elements of this type”.
See screenshot attached.
It appears to be Tuya related.
If I select for example an IFTTT action for the Logic Block it saves.
However, if I select any one of my Tuya/SmartLife devices for the action then I get the error?
It’s also happening if I try to activate a SmartLife scene as the action (not just device related).
Is this a SmartLife/Tuya limit I’ve reached?
Thanks,
Joe
Hi @joe.ferris ,
you are seeing the message because you have created 100 Tuya actions.
We have a cap set at that number for all plans. Since you are on the “Extra” subscription, we will increase the limit of actions for that plan to 150 Tuya actions.
Just give us a few days to implement the change :pray:
Thank you Philipp.
Much appreciated!
I didn’t realise how many Tuya automation scenarios I had configured :open_mouth:
Hi @joe.ferris ,
we increase the limit for all action types to 200. Should be plenty enough for a while :slight_smile:
Hi Philipp,
Many thanks for increasing that.
I’ve just tested a logic block with a Tuya action now and it’s working.
Best regards,
Joe
