"Tuya Automatic gas water valve controller" is it compatible with Apilio?
Is this device is compatible with Apilio
Shahzad Godil
That’s always a bit difficult to say without trying, because it depends on the manufacturer to implement it “right”.
Most devices work to be used in a condition.
You probably can’t send a direct command from Apilio (actions in Apilio are currently limited to on/off and are made for bulbs and switches). But if you can create a Tap-to-Run routine in the Tuya app that does what you need, you can trigger that Tap-toRun routine from Apilio.
We have it on our roadmap to make our actions more configurable and generic, so that we can offer to change any device from Apilio directly.
Hello,
Thanks for your reply
Shahzad Goidl
