Turn ON Lights Randomly between sunset and sunrise
Hello
Between Sunset and Sunrise I would like to turn ON three lamps for a random time between 3 and 5 min such as one is always ON and sequence should be random as well if possible
Lamps are controlled by Ewelink SONOFF devices.
I do have a subscription also to IFTTT Pro and Ewelink Advanced plan
I tried to figure out also with the help of POE with several different AI bots but didn’t succeed
What I do not understand is the integration between Apilio and IFTTT and or Ewelink
What should I create in Apilio?
thanks
Stefano
Hi @stepic7
it depends a bit of how much randomness you want.
Two scenarios are quite easy:
  • Fixed sequence of the lamps, but with varying On-/off durations
  • Completely independent, random sequences, but it is not guaranteed that one is always on
With a bit of experimentation and combination of multiple Logicblocks you might be able to achieve everything you want, but that needs some community ingenuity.
Here’s how Apilio works with IFTTT:
