True/almost true in conditions with delay
One addition that would be interesting is to differentiate between “true” and “almost true” in conditions with a delay setting.
If delay is 0:30:0 and the condition becomes true, then it should be shown as “almost true” until 30 mins have passed, and then it should be shown as “true” in the web interface and logs.
With the current implementation, when you look at a condition and it says “true”, you never know if it is really true or “almost true” unless you check the time stamp and the delay setting.
Sounds like a helpful little addition - thanks!
