Hi there,
I am fully new to Apilio and have to admit that I don’t really understand everything yet (probably also because of some language issues). I have problems setting up the following and would appreciate some guidance from the community.
This is the idea:
I have a Smart Life window sensor. It’s working well and through the Smart Life app I can set up an automation, that gives me a notification once the window is open. But that’s not enough for my use case. Because I’d rather like to receive this notification only after a delay of 10 minutes AND only IF the window was not being closed again in the meantime. That’s how I found my way to apilio, hoping there is a way to get this going. Do you think this possible? (working with a delay or timeout)?
As said, I am a total beginner and therefore would appreciate if someone could give me a step-by-step explanation what to setup. I haven’t really developed an understanding how Apilio actually gets in contact with that Smart Life sensor (to receive the trigger) and finally connects to IFTTT to send me that notification. It’s a bit overwhelming at the moment.
Thanks a million in advance!
This is what I have set up so far:
- in IFFTTT: “If window is open, then update the variable “window_open” to true in Apilio”
- in Apilio: Boolean variable: “window_open” → current value: “true”
- in Apilio: Conditions: “window_open_10min” → required variable state “true” → trigger locig blocks when conditions change → timeout 10 minutes
- in Apilio: Logicblocks: “window_sensor” → ifttt action with the same name “window_sensor” → execution mode immediate (no other settings filled or activated)
- in IFTTT: “If IFTTT receives a “window_sensor” event from Apilio, then send a notification from the IFTTT app”
Not leading to my goal unfortunately
Ok, I got one step further by myself. Learning by doing
In IFTTT I have set up an additional trigger “if window is closed, then update the variable “window_open” to false in Apilio”.
This was missing, otherwise the current status wouldnt change back to “false”
I then learned that “timeout” was not the condition mode helping me with my goal, so I changed to “delay” instead and that seems to have everything solved to the way I wanted it.
I also needed to learn that everything takes a while (approx. 1-2 minutes) until I receive that notification on my smartphone. It is not pushed through instantly, nor does the status in Apilio change instantly. That’s all good, I just needed to know.
So I think this can be closed here. I am all set by myself and I guess I didn’t even need to post here at all, but give it more tries before
Great post! Thanks for sharing your „learning journey“. Even if you solved it yourself, it‘s great for others to learn as well
