DanT
5 September 2019 15:00
1
I need the ability to re-check conditions after a timeout
https://groups.google.com/forum/#!topic/apilio/l3xJnNHgVrM
Anna
26 October 2020 08:31
2
If Kyle from the old forum is reading this, we launched this feature last month! And it will do just what you expect! Here’s how you can add a delay to your condition to so your automations won’t be executed if you phone temporarily disconnects from your WiFi:
With Apilio you can add delays and timeouts to some of your Conditions, so you can make your setup smarter:
What if you have a presence sensor that only sends the one event when it detects someone, and nothing else? How do you know that nobody is in the room if there is no “idle” event?
Or what if you have a sensor that sends lots of false positives. How do you know when it has finally settled on a value?
Apilio is here to help!
When to add a delay to your Condi…
Here’s the full update as well when we announced you can use conditions as triggers too!
If you are a long-time Apilio user, you probably have used the option to automatically evaluate a Logicblock whenever one of the connected Variables changes. With this new update, we are supercharging our conditions and you’ll be able to use them as triggers for your logic going forward!
[Apilio - new conditions with superpowers]
Using variables to run Logicblocks (legacy)
To prepare for this update, we started by moving that original option to evaluate the Logicblock from the Logicblock to t…
