Multiple Time of day and temp
You will have these bits in Apilio:
  • 1 boolean variable: low_temperature
  • 1 boolean condition: is_the_temperature_low
  • 1 logicblock: run_the_pump
  • 2 actions in the positive chain: turn_on_pump and turn_off_pump. The delay is specified in the logicblock in the advanced options when completing your action.
This article might help to get you started with IFTTT and Apilio:
In IFTTT you will have:
  1. One applet that sets the low_temperature variable to true, when the temperature is lower than 35F
  2. One applet that sets the low_temperature variable to false, when the temperature is over 35 F (or you can choose to reset the variable to false at a specific time of the day also)
  3. One applet that evaluates your logicblock run_the_pump every hour of the day
  4. One applet that receives the event turn_on_pump, and turns on the pump
  5. One applet that receives the event turn_off_pump, and turns off the pump
