Hello,
I want you to call me whenever someone has kept our door opened by mistake. I am just getting a single notification of alarm in “Sonoff DW1 433Mhz door and windows alarm”
I also an IFTTT customer.
Shahzad Godil
Hello,
Shahzad Godil
Thanks for posting Shahzad, are you an iphone, Android or ? phone user?
I am an Android user
Don’t know that sensor. How are you planning on getting the alarm notification into Apilio? Via Tuya/Smart Life (does that sensor work with the app) or via IFTTT or web hooks?
Once you’ve got it into a variable and condition in Apilio then you would have a logicblock trigger an IFTTT applet to call your phone (Android phone applet if you’re in the US, if not there’s a voip app you have call the IFTTT app on your phone)
I am using CallMeBot to make Apilio call me using Telegram messaging app when I need to be informed urgently about something.
You simply need to make a GET request from the logicblock to initiate a call, entering the message in the URL itself:
Before you use that, you need to give permission to CallMeBot to call you. More info here: https://www.callmebot.com/telegram-call-api/
How are you connecting the sensor to Apilio? IFTTT, Webhook, REST API or Tuya?
This device doesn’t support door and closing support even in the app. Just a single event for firing when a gate is opened.
Going to replace it with other device
Thanks for great suport
Might be a good idea to try a Tuya one. There are some door sensors we know that work on this [list](https://docs.google.com/spreadsheets/d/1dO1-JSJ71MdBz6vsRexxUPmimapp664nOHgoieUMoRE/edit?usp=sharing
I already purchased
It has a big range
Just waiting for Zigbee hub
And I am complete all work in Apilio and IFTTT.
Here is the screenshot of the IFTTT
https://tinyurl.com/yg6q444x
Screenshof of LogicBox
https://tinyurl.com/yeftluey
Screenshot of conditions.
https://tinyurl.com/yjqv73hl
https://tinyurl.com/yfp2xgu4
IFTTT variable setting on door open and closed
https://tinyurl.com/yjjm7vvr
The test is working fine
Will it work in the actual case?
Shahzad Godil
Fingers crossed, let’s see!
I think this should work, yes!
What Zigbee hub did you order? If you buy a Tula-based hub, you can use it directly with Apilio without (I have one at home and I’m also connecting Sonoff devices to it).
I ordered Sonoff one because of one past personal issue with the Tuya device.
The actual issue was that the Water leak device was showing flooded in their app but even Apilo was showing the correct status
I chatted with them also, Still unresolved.
Shahzaad Godil
mate, works this way? You ação send the Logicblocks (apilio) actions?
