I named a pattern variable,the value is “H&S pattern”,I create a contain condition “H&S”,but it return false.would you help me to slove the problem to get the true result.any help is welcome.
Hi @liequanche ,
not sure what’s going wrong with your setup.
I tried is as well and it seems to work in my case. Can you post a screenshot of the variable and the condition?
Here’s the condition setup I used:
I think the issue is that you put quotes around the search string.
Can you remove them and try again?
Isn’t it the same issue with the quotes?
the help online tell me that You can enter multiple values separated by a whitespace. I use whitespace separate the multiple words. the word in each quota must be complete.
You cannot group multiple words with quotes - that is not supported.
We have a feature request in the backlog to use commas, but that’s not done yet.
If you need to match multiple words exactly, use the “Match exactly” comparison type.
