In Apilio, you can setup timeframes that combine times of the day with your local sunset or sunrise times (or just do a sunrise to sunset for a “daytime” condition!):
Just so Apilio knows what’s your local sunset/sunrise time, you will need to setup your preferred location in your profile. You can remove your preferred location at any time.
If you go to Apilio now, there’s a new section in your profile that stores your default personal settings for logicblocks and conditions:
To remove your location, you can go back to your default personal settings and delete it. If you have any logicblocks that were using sunset or sunrise as their conditions, these will be made inactive as the times can’t be calculated without the location and it would make the conditions impossible to check.
Hi @james.a.stratman,
thanks for reporting! We had forgotten to allow the use of the map when accessed with the old domain.
It’s now fixed, but we recommend to use https://app.apilio.com anyway.
Hi @Drivingforce,
can you use https://sunrise-sunset.org to determine when your current sunrise is at your location and local time?
Because if sunrise is before 6 am, the timecondition will automatically turn into an overnight timeframe, and your result would make sense (or let’s say “work as expected”).
