Help with Fire place Automation
Ok, so here’s how you can do this:
  • Create a new boolean variable and set it to TRUE
  • Create a new boolean condition that is referring to the variable and require it to be TRUE as well
  • Create a logicblock, select the condition you just created and add two actions to the „positive“ list (second one with a delay).
That’s all in Apilio, so now all that is missing are the IFTTT applets to connect everything.
We have a huge list of applet templates which are free to use: Pick one of those if possible or create custom applets if it’s not on the list: How to connect Apilio and IFTTT
You need these applets:
  • One to „run a logicblock evaluation“ in apilio. As trigger, you can use a Google Home voice command, a IFTTT virtual bottun or whatever you want
  • One to switch off socket 1 based on your Apilio Event
  • One to switch off socket 2 based on a Apilio Event
