Using Google routines to activate logicblocks-set variables
If I am not wrong, you can fire IFTTT from Google routines and so up update apilio variables
Hey @Drivingforce,
want to share some examples? I just realise I have a Google assistant device around since recently and I haven’t hooked it up with IFTTT yet
I was thinking more of a direct integration with Apilio. Sometime IFTTT will miss a request IE set variable “a” to true. I would like to say ok google tell Apolop to set “above 30 lux boolean variable to true”
Or ok google what state is 30 lux booklean varable in (true/false)
Saves having to login to Apilion web app to check if something hasn’t happened. though Iftt does allow that using google assistant. But it does miss a beat
