Automatically toggle a boolean variable after a certain amount of time
Happy to confirm that this was released last month: timing restrictions are now being used for triggering Logicblocks and can change after a set amount of time that you specify. So instead of toggling the variable value and changing the info you got from your sensor, you can specify a condition and when that condition should be considered true in your logic.
All the details here:
